Hello Guest it is November 18, 2026, 11:49:20 AM
Author Topic: mx.wxMessageBox question  (Read 9480 times)
Offline gorf23
  •  190 190
« on: November 27, 2017, 01:55:17 PM »
Would like to know why when I run this in a dialog event function it runs no GUI lockup but have to hit enter or press ok button a lot
But if I remove the MessageBox then I get a GUI lockup...
Code: [Select]
[/ mc.mcAxisSetPos(inst,  AxisNumber, 0);        --"Zero Dro  (0 is x, 1 y, and so on)
   mc.mcCntlGcodeExecute(inst, 'G90 G0'..AxisLetter .. AxisEnteredDistance..'F1000');  -  Machine will stop at distance set
    local pos = 0
    repeat
    pos = mc.mcAxisGetPos(inst,  AxisNumber)
    wx.wxMessageBox("pos = "..pos.."  AxisEnteredDistance = "..AxisEnteredDistance)
    until pos == tonumber(AxisEnteredDistance)code]
Offline DBK
  •  9 9
Re: mx.wxMessageBox question
« Reply #1 on: December 02, 2017, 06:42:18 PM »
When you are running with the MessageBox, does the axis move and does it ever get out of the repeat loop?
« Reply #2 on: December 02, 2017, 09:01:19 PM »
I think DBK is on to the right thing.
The way I read the code is that without the intervening wx.wxMessageBox statement there is no time delay between
pos = mc.mcAxisGetPos(inst,  AxisNumber)   and
Try removing the wx.wxMessageBox and substituting some sort of delay.
Offline DBK
  •  9 9
« Reply #3 on: December 02, 2017, 09:18:36 PM »
Actually in other programming languages, when you are in a very intensive loop, that may not allow the GUI to do it's housekeeping.  VB for instance has a DoEvents command that you would call every so many iterations of your loop to ensure the GUI could respond to other events in a timely manner.  I'm not up to speed with wxLua to know it's inner workings and whether or not this would be an issue.
Offline gorf23
  •  190 190
« Reply #4 on: December 05, 2017, 11:30:01 AM »
I have tried all the delays I could think of but no good
So I decided to try a event timer, that has worked I set the timer to 1000 for now and all went well.
I checked the pos = mc.mcAxisGetPos(inst,  AxisNumber)
thought the timer function and seems ok the dro moves up and the gui doesn't lockup...
Thanks gary
