Hello Guest it is November 18, 2026, 12:21:41 PM
Author Topic: Mach4 - Laser cutting machine & "FlyCut"  (Read 8308 times)
« on: November 23, 2017, 04:21:06 AM »
Hello to the whole forum!
Use Mach4 on the laser cutting machine. Want to cut the metal "FluCut" method.
Here's the video:
https://www.youtube.com/watch?v=rDlE9u3H_iU
but I can't.
The picture shows a test GCode.
M3 - lowered the torch and turned on the laser.
M5 - turn off the light and raise the cutter.
M203 - includes only the laser cutter remains in the gap.
M205 - turns off only the laser cutter remains in the gap.
From the code M3 to M203 cutter moves smoothly, without jerks. Starting with the code M203 further, the cutter begins to stop completely. I use high acceleration and speed of the motors, the machine starts to twitch.
Is it possible to get Mach4 to cut through the metal as in the video above??
  •  9,377 9,377
Re: Mach4 - Laser cutting machine & "FlyCut"
« Reply #1 on: November 27, 2017, 12:56:43 AM »
Hi Seregius,
I have replied to your post on the Warp9 forum.
« Reply #2 on: November 27, 2017, 05:52:15 AM »
Thank you, Tweakie.CNC
A solution has been found.
