Hello Guest it is November 13, 2026, 05:56:53 PM
Author Topic: Emergency reset  (Read 35229 times)
Emergency reset
« on: October 24, 2017, 01:19:54 PM »
Hi
With latest Polabs version an Firmware
Pokeys57cnc v1.2 sometime means that Emergeny Button is pressed
but i didnt have one and the in the Pulse engine the emergency is inverted
befor i have no problems
nothing else is changed
any idea or workaround
Re: Emergency reset
« Reply #1 on: October 24, 2017, 04:56:03 PM »
Is it Possible to dongrade firmware to see if this is the problem ?
Re: Emergency reset
« Reply #2 on: October 24, 2017, 06:47:58 PM »
you say that you don't have an Estop? That's pretty bold, its about the ONLY input that has to be there.
Have you assigned a pin for an Estop? If you have then may I suggest terminating it with  a low value resistor,
say 400 ohms, to either earth or logic high so that the Estop is not active. My thinking goes that if a pin is unconnected
noise impulses may cause the signal to go active.
Re: Emergency reset
« Reply #3 on: October 24, 2017, 11:36:19 PM »
no i dint need it by now
al works great and i only milling wood
the pin inputs are standard setup
400 ohn to ground ?
Re: Emergency reset
« Reply #4 on: October 25, 2017, 12:32:19 AM »
depends on whether you've set Estop as Active High or Active Low. 400 Ohm to earth will be fine for Active High.
I can't help but think you should hook up an Estop switch, so if your machine goes crazy or your Gcode is faulty you can switch it off real quick. In most
countries an Estop is a legal safety requirement. You may have seen the switches, big red button in a yellow surround and the button latches down, hit it
and the machine stops.
Re: Emergency reset
« Reply #5 on: October 25, 2017, 02:29:08 AM »
but sorry for my missunderstand
if i have no e-stop switch it is the same as when the switch is open
my problem is thaht pokeys meas i press the estop and that is not
´must the estop switch close the connection between pin 4-6 and when i press it it cut the connection or the other way
Re: Emergency reset
« Reply #6 on: October 25, 2017, 02:40:36 AM »
I'm guessing that because you have no switch that noise is getting onto the pin and telling Mach to Estop. I suggest loading the pin so that it is less susceptible
to noise.
Re: Emergency reset
« Reply #7 on: October 25, 2017, 08:08:51 PM »
thx that work
second issue
when i milling a job
all is done and ichange the nex workpiece what can took a while
now go back to the PC
when i now want to jog sometimes it didnt work
"the device did not accept jog commands" is the message
only solution ist to close mach3 and start it agaim
Did anybody know why
thx Peter
Re: Emergency reset
« Reply #8 on: October 25, 2017, 09:00:12 PM »
you can't jog while a Gcode program is running.
Re: Emergency reset
« Reply #9 on: October 26, 2017, 05:26:46 AM »
i know
but you missunderstud or i did not explain it right
the g code programm is finished
and spindle is driving back to zero point
all done
know i can jog
when i let the machine in this state and vome back agter 10 or 15 min
and want to jog thhen i become the message
