Hello Guest it is October 30, 2026, 08:21:52 PM
Author Topic: Mach 3 Reloaded  (Read 29332 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Mach 3 Reloaded
« on: June 29, 2007, 06:39:11 AM »
You might need to create a Flash file in Mach's main directory and check to see that the two EXE's are in it for the Remote connection depending on what vertion of Mach you are using.
The updated Mach should have this already...make syre you are using the latest vertion of Mach
Here are the source file for Sothink and Flash: http://www.artsoftcontrols.com/forum/index.php?action=post;board=36.0
Check out the video "Mach 3 Reloaded": http://www.artsoftcontrols.com/forum/index.php?topic=2571.0
or
http://alphagraphicdesigns.com/Help.htm
If anything isn't working please provide the correct code or Mach OEM code, what platform your using and machine spec's if needed.
 ;DThe link to download the file is right below this text;D
« Last Edit: June 29, 2007, 08:05:46 AM by zealous »
