Hello Guest it is November 03, 2026, 02:02:32 AM
Author Topic: Mach3 Homing/SoftLimits Home Off Column?  (Read 8840 times)
« on: October 18, 2017, 08:50:12 AM »
In Mach3 Homing/Softlimits, can someone tell me what the "Home Off" field is used for?
Re: Mach3 Homing/SoftLimits Home Off Column?
« Reply #1 on: October 18, 2017, 10:47:48 AM »
It sets your home switch position to a value other than zero. If you put 5.3 in the Home off field, when you home the axis, it will set the machine coordinate to 5.3.
« Reply #2 on: October 18, 2017, 01:49:38 PM »
Cool, thanks Gerry!
