Hello Guest it is November 10, 2026, 02:30:30 AM
Author Topic: STOP command  (Read 6717 times)
STOP command
« on: October 16, 2017, 07:28:04 AM »
I have created the M101 command
ActivateSignal(OUTPUT2)
Sleep 100000
It activates fine but does not go to sleep, other posts have offered this as valid script, any ideas?
Re: STOP command
« Reply #1 on: October 16, 2017, 11:23:38 AM »
Try:
Sleep(100000)
Offline TPS
  •  2,627 2,627
Re: STOP command
« Reply #2 on: October 16, 2017, 12:08:22 PM »
hi,
if you have a look to the Mach Script Language Referenceit says:
Sleep  Sub
Sleep(Time As Integer)
so a 100000 is more than an integer can take.
Thomas
Re: STOP command
« Reply #3 on: October 17, 2017, 08:35:29 PM »
Thanks guys, I figured it out and you were helpful!
