Hello Guest it is November 22, 2026, 04:02:20 PM
Author Topic: * I Need to use a joystick to jog axis with velocity conrtol *  (Read 6776 times)
« on: October 11, 2017, 01:29:31 PM »
Hello, I am building a servo controlled gyro and would like to be able the use a two Axis joystick to control it using mach 4. I need it to work in a velocity type of fashion, where the more you move the joystick, that faster it goes.
I would also like to have a teach function like mach 3 had. So basically, I need to control motion with a  joystick and be able to replay the motion back. I will put the teach function on another post though. I am willing to pay someone to help with this. Thanks
Re: * I Need to use a joystick to jog axis with velocity conrtol *
« Reply #1 on: October 20, 2017, 01:04:13 PM »
I believe you need a device with analog inputs such as the Pokeys devices.
