Hello Guest it is November 17, 2026, 10:33:35 PM
Author Topic: Invert Z Axis  (Read 16287 times)
jamesm
Invert Z Axis
« on: June 28, 2007, 07:44:25 AM »
Good Afternoon,
I have finally set up my CNC machine and got most of it working.
Problem is I go to run a program of G Code and for some reason even though when drilling a hole the GCode reads say -2.00, my motor actually turns the wrong way and go up instead of down.
How can I tell mach to invert the Z Axis and it is currently upside down I guess.
Many thanks
James
Re: Invert Z Axis
« Reply #1 on: June 28, 2007, 07:50:57 AM »
Hey James,
    Go to config, homing/limits and check the reverse axis for your z.
jamesm
Re: Invert Z Axis
« Reply #2 on: June 28, 2007, 08:22:12 AM »
Thank you VERY much! Been flicking through the screens for the past hour and never saw that!
All is working fine now!!
Thanks again!
James
Re: Invert Z Axis
« Reply #3 on: June 28, 2007, 08:31:52 AM »
 :) Your welcome.
Re: Invert Z Axis
« Reply #4 on: March 08, 2008, 05:06:59 PM »
Thank you!  I was having problems with this exact same issue on the machine that I bought.  Now it works great!
