Hello Guest it is November 13, 2026, 10:00:44 AM
Author Topic: toolpath on rotary axis does not display properly ( a axis )  (Read 11019 times)
« on: October 02, 2017, 07:09:11 AM »
when I load a rotary job on mach3  the toolpath does not display properly when first loaded it shows as a round wheel when I home the machine and redraw the toolpath it will display the job correctly but allways puts the job at machine x-0 , y-0  not displayed at the work coordinates of the job and if I start the job I will get a soft limit warning if I ignore the warning and continue  the job will run fine   I suspect the problem has to do with the header of the g-code for a rotary job versus a flat job that is on the table top    but all the things I have tried has not worked so now I am here hoping some one will have the answer to my delima
Re: toolpath on rotary axis does not display properly ( a axis )
« Reply #1 on: October 02, 2017, 08:13:49 AM »
pics
« Reply #2 on: November 14, 2017, 12:12:36 PM »
I too am having a similar problem. I am just post here to see if you have figured this out.
Todd
« Reply #3 on: November 15, 2017, 12:32:56 PM »
no sorry but if you do find the answer please post here or email me at billjohn1962@yahoo.com  wish you luck
