Hello Guest it is October 20, 2026, 03:07:16 PM
Author Topic: Cutting slopes in foam  (Read 14996 times)
« on: June 27, 2007, 01:19:18 PM »
I need help with how to cut a ramp or slope in foam. I need to angle the egdes of my 1" thick foam. Any Ideas?
Re: Cutting slopes in foam
« Reply #1 on: June 28, 2007, 09:58:46 AM »
What do you have for Cam software? That is going to be a 3D cut :(
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 28, 2007, 02:10:29 PM »
I only have lazycam that came with Mach3.
« Reply #3 on: June 29, 2007, 08:10:30 AM »
You will need to look into other Cam software that can do 3D :( Sorry we are not able to do it at this time.
Brian
www.machsupport.com
Offline GaryB
  •  108 108
« Reply #4 on: June 29, 2007, 10:23:15 AM »
Send me your dxf with what you need and machine post processor type.
you can also just hand code it in short time if just doing a simple slope edge.
g.
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
« Reply #5 on: June 29, 2007, 11:52:00 PM »
I dont have a very big buget, with that in mind what cam programs should I look into?
Offline GaryB
  •  108 108
« Reply #6 on: June 30, 2007, 10:05:20 AM »
Depends on what you are wanting to do
For modeling you might look at Rhino about a grand I believe
You might also look at the Vectric software VCarve pro verson 4 has just been released.
ArtCam Trainer
« Reply #7 on: July 01, 2007, 02:12:53 PM »
you might try freemill, its free, i have designed stuff in google sketchup, and used a free plugin to export a 3d file, then imported it into freemill.
at work right now, so i dont have the names in front of me, but it worked.. i was using it for text at the time.
dan
