Hello Guest it is November 13, 2026, 09:47:33 AM
Author Topic: Mach3: How to Activate/deactivate a button in a macro  (Read 13513 times)
« on: September 19, 2017, 08:41:46 PM »
Mach3:
Is there a way or a function to enable/block a button programmatically in a macro so it is not clikable?
Gaston
Re: Mach3: How to grey out a button in a macro
« Reply #1 on: September 22, 2017, 03:01:55 PM »
I will try to make my question a little clearer.
Mach3:
Is there a way to grey out / un grey out a button within a macro depending whether certain conditions a met or not?
Gaston
Re: Mach3: How to Activate/deactivate a button in a macro
« Reply #2 on: September 22, 2017, 08:11:07 PM »
No, I don't believe so.
« Reply #3 on: September 22, 2017, 08:23:00 PM »
I think you can do that with LUA in Mach4...I'm not familiar enuf with VB in Mach3 to comment, ger21 thinks not and he really knows hi stuff.
« Reply #4 on: September 22, 2017, 10:04:03 PM »
I use MachScreen for screen editor and I did not find a greyed as initial state for new button so I kind of expected that it would not be possible.
Thanks Gerry and Craig for taking the time to answer.
Gaston
« Reply #5 on: September 23, 2017, 05:26:42 AM »
Hi
I've added a sample (ToggleButtonColor) on my website, which changes the color of a button, depending on the toggle state.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #6 on: September 23, 2017, 02:24:09 PM »
Thanks Klaus,
That will solve my problem,
Two questions:
 How to assure the led is off when Mach3 starts?
 Is there a way to prevent Machscreen's editor from inserting tabs automatically?
Gaston
« Reply #7 on: September 23, 2017, 04:39:05 PM »
Hi Gaston
- you could create a macro e. g. m800.m1s containing:
setuserled(1200,0)
and put that macro to your init string in general config.
- I'm not sure, this helps, but tab value can be set in Options -> Settings -> Editor Settings -> Tabulator.
Klaus
« Last Edit: September 23, 2017, 04:51:44 PM by Klaus1311 »
« Reply #8 on: September 24, 2017, 12:49:14 AM »
Bingo, that does it.
I had forgotten that a macro could be executed when mach3 starts.
Gaston
