Hello Guest it is November 13, 2026, 04:43:40 PM
Author Topic: Assign Led to step value  (Read 49538 times)
« on: September 09, 2017, 05:58:13 PM »
Hello,
How can I assign the LED to the step value Button?
Thank you in advance
Roberto
Re: Assign Led to step value
« Reply #1 on: September 10, 2017, 04:40:03 AM »
Hi Roberto,
assign Funktion "Jog mode Incr LED" (OEM-Code = 15). If you look at page 50 of the standard screen set you'll see a sample.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: September 10, 2017, 04:45:45 AM »
Make it easy by adding the Jog Mode button so you can toggle between Cont, Step, MPG.
Otherwise, have a check of the button / led / dro list if  there is a button to just select step.
« Reply #3 on: September 10, 2017, 03:46:28 PM »
I meant the led at 1.00 - 0.10 - 0.01.
By pressing the button directly without making a loop.
Roberto
« Reply #4 on: September 10, 2017, 09:22:55 PM »
Hmm.....
I didn't find a LED which is associated with any of the Jog Increment positions for 1 to 10.
May be able to add some scripting which would turn the led on/off.
Can't be of much help on the scripting.
« Reply #5 on: September 11, 2017, 04:17:01 AM »
I added 2 samples to my sample list. One of it shows how to set the jog width using a button. You can download it from my website under:
Program Downloads -> Script samples.
Klaus
« Reply #6 on: September 11, 2017, 10:45:05 AM »
I'll try to do it, but I do not think I can do it, I do not know anything about scripts.
Roberto
« Reply #7 on: September 11, 2017, 12:15:50 PM »
if you download the samples from my website, doublecliick that file. This will put the sample files into the mach directory. Copy and paste the sample screenset to your screenset page and adapt it to your needs.
Klaus
« Reply #8 on: September 13, 2017, 05:52:18 AM »
HI,
Your script and OK
The problem is that it has to perform 3 functions.
Press button 1.00
1) Performs the function of the key( Slect step value1)
2) LED ON
3) LED OFF button 0.10  or 0.01
« Reply #9 on: September 13, 2017, 09:37:26 AM »
I don't understand what you are trying to say. Could you please put your question on other words.
Klaus
