Hello Guest it is November 07, 2026, 03:17:25 AM
Author Topic: MACH4 HICON INTEGRA  (Read 16653 times)
MACH4 HICON INTEGRA
« on: September 04, 2017, 02:41:08 PM »
HI do any one have screen shots of how to set up the inputs and outputs on mach4 and Integra board I don't understand the manual how to set up the board to be able to use the motors I have a plasma table but I don't think that is a difference I can't make any of my motors move I'm using micro steppers drivers after the Integra they light up but no luck moving the motor thanks,
screen shot will be great thanks
Offline Mauri
  •  328 328
Re: MACH4 HICON INTEGRA
« Reply #1 on: September 04, 2017, 04:00:08 PM »
ikigam,
You should post your question on the HiCON Forum
http://www.machsupport.com/forum/index.php/board,89.0.html
This will ensure Vital Systems can read it an assist you.
You need to setup Mach4 Config on the Motors and also see if the HiCON Plugin Config is setup correctly.
There are other Plasma users on the HiCON forum page.
Mauri.
« Reply #2 on: September 04, 2017, 04:57:41 PM »
OK thanks do i close this ?
Offline Mauri
  •  328 328
« Reply #3 on: September 04, 2017, 05:50:37 PM »
ikigam,
yes.
Mauri.
