Hello Guest it is November 13, 2026, 09:40:46 AM
Author Topic: lazycam height  (Read 10654 times)
lazycam height
« on: August 30, 2017, 08:10:53 AM »
Is it possible to key in the height of an object? The drag and drop is very problematic.
Re: lazycam height
« Reply #1 on: August 31, 2017, 04:56:49 AM »
Have you read the manual?
Not sure what your talking about.
Re: lazycam height
« Reply #2 on: August 31, 2017, 06:40:17 AM »
I actually used the wrong terminology, I meant depth. To set the material thickness the set depth function is a drag and drop function which is very hit and miss. I would like to be able to just key in a depth to a known dimension.
Re: lazycam height
« Reply #3 on: September 01, 2017, 04:56:25 AM »
Tutorial #6 in the manual is about plunge clearance, etc.
Re: lazycam height
« Reply #4 on: September 11, 2017, 11:23:29 AM »
I know about plunge clearance. I need a more accurate way to define material thickness.
Re: lazycam height
« Reply #5 on: September 12, 2017, 04:39:42 AM »
LC is what it is and anything I know about it is in the manual I wrote.
It's not like some other CAM software. See page 18 of 23 in the manual  for my definition of what Set layer Depth does.
Thus  there is no "set material thickness". I guess if you wanted to have something appear in the graphics one could have a layer
which would represent the material foot print and set that to a some depth below Z=0.
BTW, it must be accurate as you are the one telling LC how deep to cut a layer.
