Hello Guest it is November 22, 2026, 11:31:31 AM
Author Topic: Mach3 Multiple Probe inputs  (Read 12480 times)
Offline Chaz
  •  48 48
« on: August 12, 2017, 07:36:13 AM »
I am using a CS Labs controller. How do I do multiple probe inputs?
I have a touch probe that runs as Normally Closed until the circuit is broken.
My height setter is using a simple 'make' circuit which connects 24V back into the input.
For the life of me, I cant see a logical way to allow both these to be connected at the same time, either using the same input circuit or more than 1, is it possible?
Offline Chaz
  •  48 48
Re: Mach3 Multiple Probe inputs
« Reply #1 on: August 12, 2017, 09:24:11 AM »
This is the issue. One is NO, one is NC, they cant work together, can they (without some form of a switch or disconnect).
« Reply #2 on: August 12, 2017, 07:46:41 PM »
you either need some sort of switch, probably a change-over relay or upgrade to Mach4. Mach4 allows multiple, four I think, probe
inputs which can be assigned independently.
« Reply #3 on: August 12, 2017, 07:51:02 PM »
just had another thought...how about an 'inverter' applied to one signal, that would make both signals NO or alternately NC which would
mean you could parallel both together on your probe input pin. Mach could not tell which signal had operated but at least one did.
« Reply #4 on: August 12, 2017, 09:22:45 PM »
I've written a Brain before where you can wire each probe to separate inputs, and have the brain trigger the probe input when either of the probe inputs is active.
« Reply #5 on: September 05, 2020, 11:29:26 PM »
I ran into the same problem. This got me to finally understand and write my own brain. It was simple and fixed my mixed signal probes.
Thank you.
