Hello Guest it is November 13, 2026, 12:24:03 PM
Author Topic: Using a Sevo as a Spindle and an Axis  (Read 20134 times)
Offline Katoh
  •  287 287
« on: August 03, 2017, 02:52:44 AM »
G'Day Friends
On my lathe I have finally got an AC servo to be used as my spindle, big learning curve here and lots of little pitfalls but the majority have been solved, thanks to the help of our wonderful members out there.
What I am trying to do at the moment is use the servo as not only a spindle but a "C" Axis, this is not a complex thing and I have assigned all the correct settings in Mach3 to do this, If I call C to move 50deg it does so, as C is rotational drive across Z. Normal use is as spindle and you can easily call up from 0-2000rpm quite happily. This really is a good thing and works very well on the lathe, disposes all of the changing of pulleys and simply just gives absolute control.
Now my issue begins. The servo is controlled by Step/Dir for both Axis or Spindle, the only way I can make this work is to use the same pins for both and simply disable or enable the one I want to use, no great concern but things can be better. So I assigned 2 different pins for each . EG. Spindle use Step pin1 Dir Pin14 C axis uses Step pin16 Dir pin17 all off port 1. Then the cabling from pin1 and pin16 both feed Step pin on the AC Servo Drive as do Pin14 and Pin17 connect to Dir on the Servo Drive. When I do this neither work. If I disconnect one set, does not matter which one, then axis or spindle works fine. I thought that it might be back feeding into the other pins  so I put a diode on each cable to stop any back feed, but this did not work and with the diode in place I cannot get movement at all from either set. The diode is setup so the + side is to the Servo Drive the Negative side to Mach.
For those that have more knowledge in Electronics than me is this a waste of time to use the 4 pins or am I simply missing something simple?
Thanks for reding
Katoh
Re: Using a Sevo as a Spindle and an Axis
« Reply #1 on: August 03, 2017, 06:10:16 AM »
So the software controller, namely Mach3, can instruct output to the same pins for one use only.
It's either a spindle or the  4th axis C, thus, when you manualy enable / disable Mach can approriately control output to the pins. Should be able to use macro's using Swap Axis to switch back and forth if your using a PP. If external controller it must support that command.
Lets see what other users suggest,
I would suggest you post some more info........ xml file / drive  manual / mach3 version/ hardware etc.
Offline Katoh
  •  287 287
« Reply #2 on: August 03, 2017, 06:26:33 AM »
Hi Rich
thanks for the input, just to clarify its running a smoothstepper ESS, now that may change a few things I realise now. I worked out tonight that I need to swap the direction of the diodes, that makes things work again, then I tried both of them  separately connected  C axis works correctly and spindle works correctly, connect them both even though one is ENABLED and the other DISABLED and it just wont work, that’s where I was hoping the diodes to come into there own. But even thou one is disabled it still must be sending a message through the line.
Might need a manual break switch or relay, what a pain!
Any Suggestions?
Thanks.
Katoh
« Reply #3 on: August 03, 2017, 04:10:54 PM »
Any Suggestions?
I have not followed the evolution of the SS in Long time. I believe that it supports the swapping of axes.
Start reading up on both the VB required and SS information.
In mean time someone with more detailed experience may reply.
« Reply #4 on: August 03, 2017, 07:38:50 PM »
Create two profiles. One for the Spindle, and one for the C axis.
« Reply #5 on: August 03, 2017, 11:14:41 PM »
I have a similar setup and I csn use it as a C axis but can't find a way to make it be a lathe spindle.
« Reply #6 on: August 04, 2017, 01:35:34 AM »
if I understand what you're trying to achieve is to have two sets of step/dir pins and select one set depending on the behaviour required for the servo
at this instant?
If that is the case then you can't combine the pin sets passively. A passive combination network cannot prevent both high AND low states from propagation.
That would require an active network, aka a multiplexer. Probably the simplest would be some CMOS bilateral switches but could also be achieved by
paralleling two tri-state buffers...If you are interested I could sketch up a couple of circuits that might work.
« Reply #7 on: August 04, 2017, 01:37:57 AM »
in fact even simpler would be a DPDT relay...
« Reply #8 on: August 04, 2017, 01:56:54 AM »
this might work
Offline Katoh
  •  287 287
« Reply #9 on: August 05, 2017, 11:29:43 PM »
Hi Friends sorry the late reply.
Do you mean have two separate XML files one for C drive and One for spindle? Sounds very cumbersome re-starting Mach every time you wish to swap, but should work.
I can help you with that What sort of servo are you using?
at this instant?
Yes, and yes I can see that i will not be able to get them to work together.
Brilliant! That will work and can be activated by a button the the screen controlled by an output! The drawing is spot on I looked at the multiplexer but have no clue on how to wire that up, its a little beyond me, but the double relay is a piece of cake.
Thanks Everyone!
Katoh
