Hello Guest it is October 20, 2026, 07:10:18 AM
Author Topic: mach4 mw sumulator problems loading  (Read 8074 times)
Offline gorf23
  •  190 190
« on: July 26, 2017, 10:39:47 AM »
I installed the mw simulator on mach4 all the files seem to be located properly in the plugin folder but
when I boot mach4  I get the error message failed to load shared library mwsim.m4p error 0 , and it will no show up in the mach4 plupins
this is on a registered version of mach4.
Any idea's :
Thanks gary
Offline Mauri
  •  328 328
Re: mach4 mw sumulator problems loading
« Reply #1 on: July 26, 2017, 08:01:42 PM »
gorf23,
You must have the following MW files in your Plugin Directory for MW to work. (see below)
Mauri.
Offline gorf23
  •  190 190
« Reply #2 on: July 27, 2017, 12:13:33 PM »
yep that's the first thing I checked....
I have a demo ver of mach4 installed on a different and it loads the plugin on that system ok..
I on I have mach4 reg version doesn't have much software on it no virus protectors or anything like that
loads on the computer with all that software but won't run on the clean computer have pokeys and smoothstepper
plugins they run fine...
gary
Offline Mauri
  •  328 328
« Reply #3 on: July 27, 2017, 02:28:59 PM »
gorf23,
Copy your current Mach4Hobby full directory somewhere else on your computer system.
Then rename the directory to say Mach4HobbyMW.
Make sure that your have all the MW files in the Plug in.
Also make sure that in your profile you have the ModuleWorks directory.
Make sure that the Licenses are in the License directory for MW.
Then move the Mach4HobbyMW directory back to C:\
Then this will be used a the MW only and the other will be used for your Milling Machine.
If that does not work then reinstall MW onto this new directory.
Mauri.
Offline gorf23
  •  190 190
« Reply #4 on: July 28, 2017, 12:35:41 PM »
It is fixed it seems sometimes not all the widows dll files are installed.
what I had to do was put vcomp120.dll into the plugin folder now it works...
Gary
