Hello Guest it is October 20, 2026, 02:51:11 PM
Author Topic: Variable Frequency Drive operation from Mach  (Read 8912 times)
Offline c30232
  •  122 122
« on: July 23, 2017, 04:21:09 PM »
I wish to control a router spindle from VFD via Mach.  Unfortunately, I do not have a schematic/manual for the BOB.  Nor can I get the seller to provide information beyond that the feature is on the BOB.
I found a dull and corroded terminal pair that were away from the rest.  I guessed at the pin.  I am able to switch the spindle on and measure 2 volts at the terminal.  That's the end of progress.
The terminal seems to have a sub-board section related to just that pair.  There is a pot on that section.  Dialing the pot does not change the voltage.
If I have found the correct terminal then the issue is within Mach.  How do I best configure Mach in order positively identify the terminal and set the voltage range?
Re: Variable Frequency Drive operation from Mach
« Reply #1 on: July 23, 2017, 04:25:26 PM »
Start by posting a picture of your board.
Then tell us what model the VFD is, and what terminals on the VFD the wires from your BOB go to.
Offline c30232
  •  122 122
« Reply #2 on: July 23, 2017, 05:11:37 PM »
See attached.  I am searching for a manual for input terminals.  I thought output voltage would be good to find before crawling under to have a go at the VFD.  The VFD will soon be easily accessible, we are removing the vacuum table to access the gantry attachments.
Offline c30232
  •  122 122
« Reply #3 on: July 23, 2017, 06:00:25 PM »
More data attached.
