Hello Guest it is November 21, 2026, 03:48:31 PM
Author Topic: Video device  (Read 8203 times)
Video device
« on: July 23, 2017, 02:36:29 PM »
Hay all.
In Mach4 is a separate videocard necassery??
Willem
Re: Video device
« Reply #1 on: July 23, 2017, 03:13:46 PM »
Interference with parallel port step signal timing due to motherboard
video access is usually less for modern motherboards, and does not
matter at all unless you are running the legacy Darwin parallel port
driver. For any system running an Ethernet or USB connected
motion controller, video interference is not an issue.
Video performance can still matter. Mach4 uses Open GL video
drivers and needs reasonably good hardware. If you are running
G code files with megabytes of short segment movements such as
photo carving, you will need to have a couple of Gigabytes of
memory available for video, either motherboard or dedicated card.
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
Re: Video device
« Reply #2 on: July 23, 2017, 03:24:31 PM »
Thanks Steve
Just one more question:
What will happen if the memory is insufficient ?
Thanks again
Re: Video device
« Reply #3 on: July 23, 2017, 03:44:52 PM »
The Open GL video data will page to disk and there is a dramatic impact
on screen update speed.
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
Re: Video device
« Reply #4 on: July 23, 2017, 04:56:49 PM »
Thanks for the explanation
Wllem
