Hello Guest it is November 22, 2026, 07:04:05 AM
Author Topic: home x homes all axis'  (Read 10443 times)
« on: July 07, 2017, 11:45:01 AM »
I had my machine working just fine.
I created a button that said "home x" and it would home x
Now when I press the same button, it homes all axis' as if I hit "ref home"
Any ideas?
Ben
Re: home x homes all axis'
« Reply #1 on: July 07, 2017, 12:57:31 PM »
I will also add that I am able to use "G28.1 X1."
But I just can't figure out why all of the sudden "home x" or DoButton(24) continues to home the z axis, then the y axis, then the x axis.
I am using a Warp 9 ESS and a PMDX 126.
I did add some outputs, which function perfectly.  I did disable a relay on the PMDX as it was using up an output pin...
I am stumped,
Ben
« Reply #2 on: July 07, 2017, 05:07:06 PM »
Is the homing script in the button, or in a macro called by the button?
« Reply #3 on: July 07, 2017, 07:55:45 PM »
I created a button in a screen designer, I simply selected the radio button for home x, so no macro was created
« Reply #4 on: July 10, 2017, 02:43:07 PM »
I discovered my problem...
In the screen designer, the old "ref all home" phantom button still existed in the 'background'. Once it was fully deleted the problem went away.
