Hello Guest it is October 21, 2026, 03:28:46 PM
Author Topic: Fanuc Pulse Coder  (Read 26942 times)
Offline TPS
  •  2,627 2,627
Fanuc Pulse Coder
« on: July 06, 2017, 10:19:32 AM »
on my TongIL retrofit Project, i am at the spindle now.
the spindle has a pulse code A20B-9000-0380.
on the web i found two different types.
i have the the one with the following signals:
0V -> GND
5V -> Power supply
VA
VA/   the Sinus wave
VB
VB/  the Cosinus wave
so far so clear and i can measure the signals with the scope
then we have a
VZ witch should be the Zero pulse
the is no VZ/.
i have measured VZ to GND allways 2,5V
i have measured VZ to 5v allways -2,5V
i was never able to see a pulse on the scope.
maybe one of you has got any further ideas.
Regards Thomas
