Hello Guest it is November 01, 2026, 10:12:24 AM
Author Topic: Unexpected Error  (Read 9667 times)
Unexpected Error
« on: June 23, 2007, 02:35:10 PM »
Hi Art. When I loaded the attached dxf file into LazyCam (v 2.076 and 2.05) I found one of the entites distorted off the screen ("Before" screen capture). Cleaning did not help. However, I found that rotating it 90 degrees brought the entity back to where it belongs ("After" screen capture). Is there something in the dxf file causing this or is it in LaztCam? Thanks.
Best Regards,
Mike
Re: Unexpected Error
« Reply #1 on: June 25, 2007, 08:28:02 PM »
I will have a look at your DXF... I think I know where the problem is :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 25, 2007, 08:30:59 PM »
I tested it here and it is working ... I will update may code with Art and see if there is a bug in his Rev.
Brian
www.machsupport.com
