Hello Guest it is October 22, 2026, 09:33:19 PM
Author Topic: Mach4 Configuration for PMDX-407 speed control  (Read 9460 times)
« on: June 26, 2017, 07:42:25 AM »
Hi  I have a PMDX-424 USB Smart BOB fitted with a PMDX-407 spindle control on a Bridgeport Series 2 CNC .The 424 works great ,the 407 ,starts the Telemecanique VFD via Mach4 , It starts with the lower speed that is programed in the Mach4 spindle configuration setup. If set to 0 it will not start. When Spindle percentage slide bar is moved , speed does  not increase . Can any one help .
THANKS
Re: Mach4 Configuration for PMDX-407 speed control
« Reply #1 on: June 26, 2017, 09:51:45 AM »
If the spindle is starting with the lower speed specified in the Mach4 configuration,
then it sounds like the speed control is working. Just to be sure, please try changing
the minimum speed in the Mach4 configuration to see if it does affect the actual
spindle speed. If it does not, there is likely a problem with the wiring or the
parameter configuration in the VFD.
If it does change, there is likely a Mach4 configuration issue. In this case please
create a "packaged profile" and post it here or send it directly to PMDX for us
to analyze.
You can create a packaged profile using Mach4 by using:
HELP > Support > Create Packaged Profile
.. and save the resulting file somewhere that you can find it to send to us.
This file will contain all configuration information for the Mach4 profile that
you are running at the time it is created.
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
« Reply #2 on: June 27, 2017, 11:07:46 AM »
Hi Thanks for your fast reply. The spindle speed changed, when changed in Mach4 spindle configuration  .
« Reply #3 on: June 27, 2017, 11:22:19 AM »
Well that proves that the PMDX-407 is able to cause the spindle speed to change.
The most likely remaining problem is a spindle pulley configuration problem.
If you send us a packaged profile, we will take a look at it.
Steve Stallings
www.PMDX.com
« Reply #4 on: June 27, 2017, 11:25:33 AM »
Yes send a package profile in private did you receive it.
« Reply #5 on: June 27, 2017, 06:55:44 PM »
Yes, we got your packaged profile and it does seem to work for us.
It was set to minimum 2000 and maximum 4000. I tested with S3000 and used
the spindle speed override and was able to make it track from 2000 to 4000
on the display and had the corresponding change in output voltage and
brightness of the PWM LED on the PMDX-407 board. The LED brightness
is not easy to see, so I set the minimum speed to 1 and verified that it
would cover the full range.
Things that may be causing you problems:
1) The slider is for spindle speed override as a percentage of the speed
     set by the current S word. If the current S word is 0 then 200% of
     zero is still zero.
     When the commanded S word is less than the minimum speed, Mach4
     will force the speed to the minimum. This will not change the actual value
     of the commanded S word, only its effect on the spindle.
     If you have not entered or executed an S word command the S word
     will be Zero which will be evaluated as the minimum speed which you
     had configured. This could explain why the minimum speed configuration
     would affect your spindle speed but the slider would not.
     You can set the value of the current S word using a command such as
     S4000 in the MDI window.
     The slider is not a full range speed control and it will also not go outside
      the range set by the minimum and maximum.
2) MDI commands are not activated by a Carriage Return alone. In Mach4
    you must click on Cycle Start which will run all the commands in the MDI
    window.
« Last Edit: June 27, 2017, 06:57:33 PM by Steve Stallings »
Steve Stallings
www.PMDX.com
