Hello Guest it is November 22, 2026, 04:58:32 PM
Author Topic: Is it hard to hook up and external temp guage to display in a DRO?  (Read 7594 times)
Offline Tarak
  •  229 229
Theoretically, I thought it could be done.
I'm told the temp guage I'm looking at has 3 wires, I haven't looked into what they are yet.
Thanks.
Darc
Re: Is it hard to hook up and external temp guage to display in a DRO?
« Reply #1 on: June 23, 2007, 09:58:30 AM »
Yes,  You need to a Analog to digital converter, unless you guage already puts out digital signal.
I use a A-D module in a PLC, then bring that value into the macro pump, and convert it, and put it on a dro.
I think John, and some others using Peters board have done it in different ways, see if Peter will answer you.
You can also use a thermo couple module, but you still have to do the above.
Scott
