Hello Guest it is October 21, 2026, 12:08:34 PM
Author Topic: Changing feed rate  (Read 6646 times)
Changing feed rate
« on: June 14, 2017, 04:01:36 AM »
Can someone advise if theyre having the same problem. When just running along a straight path (so y not changing) the feedrate varies quite signifiicantly? The feed you can see is changing all of a sudden from fast (1000mm) to slow (300mm) and then back up again  and the same when x isnt changing???
