Hello Guest it is November 13, 2026, 09:36:14 AM
Author Topic: MachX threading  (Read 16322 times)
MachX threading
« on: March 19, 2006, 12:01:12 PM »
When my homebuilt 4 axis mill/lathe is at stage to install electronics I will buy Mach X so it has all the latest bells and whistles installed.
  I am building a 24" by 120" mill/lathe to do wood columns.  This is designed to be a CNC version of the Legacy Ornamental Mill.  I will normally use profiled router bits to cut rope and barley twists and since they will cut the desired profile I think that I can use the thread wizard to do this but not sure of values to enter.
  Column 12" diameter by 120"
  Router bit 3"
  6 starts
  1 rotation per 18" (thread pitch)
  depth of cut .1" per pass total of 6 passes per thread
  speed 200 IPM
  CW or CCW selectable
The columns are glued up as a octagon and I think that the high points can be knocked down via slot cutting wizard
  octagon diameter 12.98"
  column diameter   12"
  using 2" flat bottom bit
  depth of cut .1"  repeat 8 times rotate 45degrees and repeat 7 times
speed 200 IPM
To flute columns
 column diameter 12" length of cut 100"
 start cut 10" from end
 depth of cut .1" X number of cuts
 rotate X degrees and repeat X numbers of times
Are these possible or would writing G code be as easy as I suspect?
 depth of cut
Re: MachX threading
« Reply #1 on: March 19, 2006, 12:14:52 PM »
If you would like to have wizards done to make the Gcode I can help you out... I can show you some VB code that you can modify OR I could write some for you,
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: MachX threading
« Reply #2 on: March 19, 2006, 12:34:28 PM »
Defiantly would be interesting in being able to write wizards to do the steps/job.  Most of my work is fairly standard with variables being diameter, pitch and length.
