Hello
Guest
it is
November 22, 2026, 06:53:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Basic touch off switch function needed for PCB
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Basic touch off switch function needed for PCB (Read 10084 times)
deleteallusers
on:
June 22, 2007, 01:26:22 PM »
Can’t I just hook up the NEG wire of the ESTOP to the tool head and hold the POS lead to the surface of the COPPER PCB material and move the tool down slow until it triggers an estop then just Backoff 0.0001 or so and zero the machine.
I know there are more elagent ways to do this but I’m having problems with the screen
Interface and I don’t have time to mess with it now! I just need a solution.
Is this not the same thing as a regular touch off switch (using estop insted of prob) ? I can't figure out how to use the probe input like this ?
So what difference does it make anyway ? I dont have time to learn a new programming method.
Last Edit: June 22, 2007, 01:28:47 PM by deleteallusers
deleteallusers
Re: Basic touch off switch function needed for PCB
Reply #1 on:
June 25, 2007, 09:46:21 AM »
Well, for such a simple question, I'm amazed that no one has responded.
That does not give me much confidence, that I will be able to be succussfull with the software.
Chaoticone
5,624
Precision Chaos
Reply #2 on:
June 25, 2007, 10:03:37 AM »
I think the reason no one has jumped on this yet is beacuse of all of the other questions that will have to be answered.
I have sent you a personal message.
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
Go Up
« previous
next »
