Hello Guest it is October 24, 2026, 11:06:18 AM
Author Topic: Mach3 Driver  (Read 8980 times)
Mach3 Driver
« on: May 27, 2017, 05:19:20 PM »
Is there a driver download for Mach3  seems to me I saw in my control panel in programs a mach3 driver I am wondering if I am missing the driver.
Re: Mach3 Driver
« Reply #1 on: May 27, 2017, 06:05:54 PM »
try the following:
Mach3 CNC Controller
Software Installation and
Configuration
[/2.1.2.2 Run the Mach3 software installation package.quote]
from the Artsoft site.
Re: Mach3 Driver
« Reply #2 on: May 27, 2017, 09:32:44 PM »
I uninstalled Mach3 and downloaded from the the download on this and when I try to do a driver test I get this; No driver sensed installed. Run Driver Test. I just do not get it.
Re: Mach3 Driver
« Reply #3 on: May 27, 2017, 09:41:09 PM »
Are you using a 64 bit OS? If so, the driver won't work, unless you use a 32 bit version of Windows 7 or older.
