Hello Guest it is November 25, 2026, 05:30:27 AM
Author Topic: How can I use more outputs to drive relay?  (Read 18653 times)
chenpeiguo
« on: March 19, 2006, 08:55:07 AM »
I know M3 M4 M7 M8 can drive relays,how can I drive more relays?
Re: How can I use more outputs to drive relay?
« Reply #1 on: March 19, 2006, 10:45:16 AM »
You can use as many as you like... If would like to use the P port it can be done with Output #1 -20. To use them you are going to have to make Mcodes to turn them on and off.
Example:
'M100
ActivateSignal(output4)
'M101
DeActivateSignal(output4)
www.newfangledsolutions.com
www.machsupport.com
chenpeiguo
« Reply #2 on: March 20, 2006, 10:28:53 AM »
Thank you very much!
I will try to do a test.
cosmynnec
« Reply #3 on: May 15, 2006, 03:41:01 PM »
How can i do an Mcode ?
« Reply #4 on: May 15, 2006, 05:16:20 PM »
You need to save the code to your Mach3Mill (or Mach3Turn) folder. Like this:
Save as Mach3/macros/Mach3Mill/m100.m1s
Save as Mach3/macros/Mach3Mill/m101.m1s
Works good just tested it.
Darek
