Hello Guest it is November 12, 2026, 10:59:17 AM
Author Topic: Help - Mach 3 toolpath blip om boundry line?  (Read 14134 times)
« on: June 22, 2007, 01:09:10 AM »
Hi - Hopefully my screenshot attachment shows a toolpath blip near a boundry line. This is not on the G code - but only appears when opened with Mach3 - The cutter follows the blip - help welcome!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Help - Mach 3 toolpath blip om boundry line?
« Reply #1 on: June 23, 2007, 06:13:05 AM »
Hi, post your g-code and lets have a look and see if it is the same on my setup.
Graham.
« Reply #2 on: June 23, 2007, 08:50:38 PM »
Thanks Graham - g-code should be attached.
I have now tried similiar codes from similiar toolpaths and some codes give the blip - and some do not.
Regards :)
  •  2,785 2,785
« Reply #3 on: June 24, 2007, 04:23:28 AM »
Hi Cliffh,
I think the problem is to do with the arcs,  if you go into general config and change the IJ Mode I think all will be OK.
Graham.
« Reply #4 on: June 24, 2007, 05:31:38 PM »
Many thanks Graham
I changed the IJ mode to inc and all is well.... I see ex the mach 3 manual 5.6.6 that this is a compatability setting.  I thought my supplier asked me to set to ABS - do you know if there is any downside to this setting I need to be aware of ? I could leave it in ABS mode and just change to inc when I have to?
Regards
  •  2,785 2,785
« Reply #5 on: June 24, 2007, 05:41:24 PM »
The inc / abs IJ mode can be changed at will, if you are using a cam system that puts out abs arcs then you can modify the post processor to output a G90.1 on a line of its own somewhere at the top of the program. For inc arcs then the post needs to put out a G91.1
You will find that most programs output arcs as incremental.
Graham.
« Last Edit: June 24, 2007, 05:44:35 PM by Graham Waterworth »
« Reply #6 on: June 24, 2007, 09:19:20 PM »
Thanks again Graham
