Hello Guest it is November 22, 2026, 09:30:37 AM
Author Topic: How to use the keyboard ESC key to stop all movement.  (Read 16060 times)
« on: May 22, 2017, 02:08:26 AM »
The Feed Hold does work when I press the Space bar. Using it as an example I tried to make the Esc key do the stop function but it errors out on me. Below is the code...
Any suggestions will be greatly appreciated.
--this works for the Feed Hold
if mc.mcSignalGetState (mc.mcSignalGetHandle (inst, mc.ISIG_INPUT63) == 1 then
     mc.mcCntlFeedHold (inst)
else
     --  Do something else
End
_________________________________________________________________
--This errors out
if mc.mcSignalGetState (mc.mcSignalGetHandle (inst, mc.ISIG_INPUT623) == 1 then
     mc.mcCntlcycleStop (inst)
else
End
Re: How to use the keyboard ESC key to stop all movement.
« Reply #1 on: May 22, 2017, 06:31:12 AM »
Check your capitalisation in mcCntlCycleStop. Upper and lower case C look similar.
Allan
« Reply #2 on: May 22, 2017, 10:21:01 AM »
Thanks, but i do have with as mc.mcCntlCycleStop with the capital C's in the code I was trying. I just didn't get it right when I typed my question in the forum.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: May 22, 2017, 01:55:09 PM »
Check your INPUT number mach4 doesnt have 623 inputs..
DazTheGas
« Reply #4 on: May 22, 2017, 03:11:50 PM »
Another error when entering message. The actual code does use input 62 not the 623 that I show above.
I have to learn to type more accurate and reread my messages.
Below is a copy and paste of what is in Mach4
if mc.mcSignalGetState (mc.mcSignalGetHandle (inst, mc.ISIG_INPUT63)) == 1 then
    -- mcSignalWait(inst, ISIG_INPUT63, WAIT_MODE_Low, 0)
else
end
--if mc.mcSignalGetState (mc.mcSignalGetHandle (inst, mc.ISIG_INPUT62)) == 1 then
--    mc.mcCntlCycleStop (inst)
--else
--    --   Do something else
--end
« Reply #5 on: May 22, 2017, 05:02:30 PM »
Why  are you showing the second section as  all commented  out? What code are you actually using?
Allan
« Reply #6 on: May 22, 2017, 05:21:57 PM »
The first one is for Feed Hold which works, the commented out one is for the stop which does not work when the comments are removed.
« Reply #7 on: May 23, 2017, 09:48:21 AM »
OK.  I can't see a problem with the script itself. Let's go to the next step.
Have you set up an entry (or checked that one exists) in the Keyboard plugin and assigned this to Input 62 in Mach4's Input Signals tab?
Allan
« Reply #8 on: May 23, 2017, 10:12:56 AM »
Yes, they seem to be correct. Checked the keyboard inputs and Mach input signals.
« Reply #9 on: May 23, 2017, 12:31:47 PM »
Have you tested with some key other than esc. ?
