Hello Guest it is November 07, 2026, 08:15:22 PM
Author Topic: How to display current Coordinate System G54, G55 ...  (Read 9741 times)
« on: May 20, 2017, 01:51:34 PM »
Hi. I need to know how to make an DRO to show what is my current CS It can allso be LED's with label G54, G55..
I would allso like to set G90 or G91 with buttons on screen. Cant find out how to do this...
Thanx  :)
Re: How to display current Coordinate System G54, G55 ...
« Reply #1 on: May 22, 2017, 03:24:59 PM »
Is there no one that can help me here ?
I found out how to display what offset curently in use.. But how can I have a display that tells me what Distance Mode I am currently in? G90 or G91... ???
Yes.. I know about the Modal code line.. Just want it a bit more easy to see another place on screen...
« Reply #2 on: April 10, 2018, 08:10:02 AM »
Hey Soruud,
You would be better off putting future posts in the Mach 4 General Discussion and not here in the Mach 4 Toolbox.
But, I can answer your question on displaying the G90 or G91.
Open the screen editor and place a DRO anywhere you want to display G90 or G91.
Set the DRO's Parameter to 4003.  This will link it to the register that holds the value of the G90 or G91.
Chad Byrd
« Reply #3 on: June 26, 2018, 01:53:43 PM »
where we can get the all parameters list  ?
« Reply #4 on: June 26, 2018, 01:58:31 PM »
KatzYaakov,
There was a thread just this past week discussing parameters and 2 lists came out of it.  Bryanna posted a Txt document that had a large list in it and the Mill Programming Manual has a large list in chapter 6.
Check the thread out here.
http://www.machsupport.com/forum/index.php/topic,37575.0.html
Chad Byrd
