Hello Guest it is November 13, 2026, 08:46:17 PM
Author Topic: How to create customized drawing of G-code?  (Read 19941 times)
« on: May 11, 2017, 06:54:24 AM »
Tell me, please, how to create customized drawing of G-code?
How can I do this in Mach3?
I'm going to do this via m1s-script, but I can not find the graphics commands.
Like this:
Or in window:
« Last Edit: May 11, 2017, 06:57:09 AM by Macho3 »
  •  9,377 9,377
Re: How to create customized drawing of G-code?
« Reply #1 on: May 11, 2017, 07:16:05 AM »
You can, to some extent, do this using the 'Teach' function and the keyboard arrow keys but I suggest you use a CAD/CAM program - it does a much better job.
« Reply #2 on: May 11, 2017, 07:23:07 AM »
Thank you!
But I need to get the data about a loaded g-code and custom draw it.
This is need for the machine operator.
  •  9,377 9,377
« Reply #3 on: May 11, 2017, 07:33:14 AM »
I think you are expecting too much from Mach3 which is just a Machine Controller - it does not have a CAD function as such.
« Reply #4 on: May 11, 2017, 07:40:07 AM »
I do not expect Mach3 to do it for me. I want to make the program myself (for example, in Visual Basic or Visual C ++) for customized drawing.
  •  9,377 9,377
« Reply #5 on: May 11, 2017, 07:46:22 AM »
obviously nothing is impossible but there is no way you can code that into Mach3.
« Reply #6 on: May 11, 2017, 07:55:32 AM »
You can make a drawing of a gcode program. This is called backplotting. It basically provides the instructions to
the CAD software on how to draw each coded line. So you get a drawing  of the pathing. You can buy a backplotter program  like NC Plot ($300) or some others.
I use a custom backplotter ( sorry,  can't  share it ).
« Reply #7 on: May 11, 2017, 08:19:27 AM »
Thanks for your reply!
Can you tell me more information about this?
How did you develop your custom backplotter?
« Reply #8 on: May 11, 2017, 08:27:29 AM »
I looked, NCPlot is a independent program.
I have the my independent program for viewing g-code.
But I need to integrate it into Mach3 (or create new program for Mach3).
« Reply #9 on: May 11, 2017, 11:52:05 AM »
Friends, I found a solution: I call the browser using CreateObject in m1s and pass the data to it for drawing.
