Hello Guest it is October 21, 2026, 08:54:25 AM
Author Topic: Z probe using a 3D printer bed levelling sensor?  (Read 16346 times)
« on: May 04, 2017, 09:41:14 AM »
I haven't jumped into 3D printing yet but keep running into inexpensive cool items like this: http://www.ebay.com/itm/Geeetech-3D-Touch-Auto-Bed-Leveling-Sensor-for-Prusa-3D-Printer-/322501978412?hash=item4b169da92c:g:0nMAAOSwGtRXw~nk
Wouldn't one of those things be useful for setting tools on a mill or router with existing Mach3 software?
Milton from Tennessee ya'll.
  •  9,374 9,374
Re: Z probe using a 3D printer bed levelling sensor?
« Reply #1 on: May 05, 2017, 12:38:01 AM »
Cool gadget indeed, thanks for sharing.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: May 05, 2017, 05:12:35 AM »
Ooh, nice,
wonder if that could be adapted to work on a plasma cutter for top-of-material sensing????
« Reply #3 on: May 05, 2017, 06:54:29 AM »
Won't work.
The difference is additive versus subtractive machining.
The bit on the CNC would be cutting on an angle whereas the extruder on a printer places layers down so the angle doesn't make enough of a difference to matter.
  •  9,374 9,374
« Reply #4 on: May 05, 2017, 07:05:42 AM »
Won't work.
I am sure it will.
Not sure that has anything to do with bed leveling or plasma top of material sensing.
I think you may need to explain your answer in a bit more detail.
« Reply #5 on: May 05, 2017, 12:10:16 PM »
Won't work.
I am sure it will.
Go ahead and try it.
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: May 05, 2017, 01:09:23 PM »
Won't work.
I am sure it will.
its a surface probe, i can't see any issue with the type of machining?
« Reply #7 on: May 05, 2017, 01:49:56 PM »
The intended purpose of the sensor is not to compensate for an out of level table or z-axis.  It would be used as a simple z-axis probe input to accurately locate the work surface or the tool tip for cheap.  Taking advantage of cheap as chips Chinese 3D printer technology. :)
Me being me, I will need help making it play nice with Mach if I decide to try one.  I guess it will require a macro or the like? :-[
Offline Davek0974
  •  2,606 2,606
« Reply #8 on: May 06, 2017, 02:18:30 AM »
It might need some interfacing - the blurb mentions servo input, pwm, solenoid etc, I cant find much out about the internals or the sensing method used but if the repeatability is anywhere near as good as stated it must be worth a try i think.
Also, being for 3d printers which are generally lightly built, i would presume the surface contact pressure is very low which would be good for TOM sensing in a plasma cutter :)
« Reply #9 on: June 18, 2017, 08:58:36 PM »
Of course it will work.  Its just a fancy limit switch.  You can do probing with any device that can provide a switching function upon sensing a surface.
The 3D printing community is quickly moving to non-contact proximity sensors for print bed zeroing, bed leveling, and now XY Axis skew correction (corrects for X and Y axis not perpendicular).
Your choice of sensor (or switch) depends on the accuracy you need.  If you go with non-contact, there are many different types depending on the sensing technology and accuracy needed (i.e. Inductive, capacitive, etc.)
Below are a couple of examples.
http://www.ebay.com/itm/LJ12A3-4-Z-BX-Inductive-Proximity-Sensor-Switch-NPN-DC6-36V-3D-Printer-CNC-/122184058393?hash=item1c72bcc619:g:rG8AAOSwNRdYAyiX
