Hello Guest it is November 13, 2026, 10:53:15 PM
Author Topic: zeroing axis ( A axis ) in G Code  (Read 9799 times)
« on: May 02, 2017, 02:37:48 PM »
Hello to all ,
can someone give me some hints  how to Programm a axis zero in the G code ?
So my rotary A axis got no homing position. Always I start the program I have to reset to zero by pushing the button.
Now I thought about programming it in a g code at the end of the program or maybe at the beginning ....doesn't matter ....
Is it possible to do that by a gcode ?
Thank you
Re: zeroing axis ( A axis ) in G Code
« Reply #1 on: May 03, 2017, 06:31:02 AM »
First check General logic configuration and understand the impact of checking any of the "Rotation" boxes and the distance mode also.
Create a macro to do whatever you want to do, then call the macro in your program code.
« Reply #2 on: May 03, 2017, 07:22:19 AM »
Hello Rich
I only want to reset the DRO of the A axis.
So that with a new start of the program, the Dro is set to 0.
I don't understand anything about making macros
  •  9,377 9,377
« Reply #3 on: May 03, 2017, 09:40:10 AM »
If you insert in your Gcode the line:
#99803=0
that will reset the A axis DRO to 0
