Hello Guest it is November 13, 2026, 10:43:48 PM
Author Topic: Auto zero wiring with uc100 adapter  (Read 11571 times)
« on: May 01, 2017, 06:55:08 AM »
Is there any instructions in wiring probe with uc100 being used instead of p/p. Also it would help if I was for dummies . I have looked everywhere and either I am wording it incorrectly or I need more help than I think
Thanks Chuck
Re: Auto zero wiring with uc100 adapter
« Reply #1 on: May 01, 2017, 04:52:59 PM »
 What breakout board are you using? Are you using a probe, or do you want to zero the tool to a plate?
« Reply #2 on: May 02, 2017, 06:54:14 PM »
I don't know, where would I look for that. A db25 board came with a parallel cable but was not used, instead bought a uc100. There are a couple of other ports on the back of the control box, one of which is the 4th axes plug. The other looks like a printer port cable.
I have Chinese machine since I am just starting this cnc life. I am 67 y.o and probably over my head. Fairly well computer ok, can read & write and follow instructions w/pictures ( just kidding on the picture part ), but will take it if I can get it.
Thanks for the assist
Chuck
« Reply #3 on: May 02, 2017, 07:01:22 PM »
Also have a probe small plastic circle thing with small aluminum center w/ black, white wire w/ alligator clips. Best I can describe
« Reply #4 on: May 02, 2017, 07:27:08 PM »
Can you post some pictures of what you have?
« Reply #5 on: May 02, 2017, 08:04:37 PM »
Sure, how do I do that on here?
« Reply #6 on: May 03, 2017, 11:09:13 AM »
When you click on reply, click "Additional Options in the lower left corner. Then Attach: Browse to select files.
