Hello Guest it is November 10, 2026, 02:21:35 AM
Author Topic: Direct DRO input without hightlight DRO  (Read 7049 times)
« on: April 28, 2017, 05:47:04 AM »
Hello,
I'm working on a custom screen for a project I'm doing.  What I would like to do is have a "keypad" on the mach screen that is made up of buttons. and the buttons when touched would direct input to a DRO .. I know about SetOEMDRO. and that may work but what I am wanting is to have number keys like a number pad and then also have fraction keys... so if I want to input 12.0625 into the DRO I would just hit  button "1" "2" and button "1/16" then "enter".  I know I could do this with a keypad but I would like to not have to select the DRO but rather any time I hit those buttons it inputs what I hit to the DRO
I'm not sure if this is actually possible though using a macro and SetOEMDRO?
Thanks!
Jeff Tice
Offline TPS
  •  2,627 2,627
Re: Direct DRO input without hightlight DRO
« Reply #1 on: April 28, 2017, 11:07:01 AM »
hi Jeff,
i am not realy sure, what you like to do, but if i understand you right something like this should work:
lets say you like to modify OEMdro2000 and you hit the "key" 1 on your virtual Keyboard the VBmakro for KEY1 could
be something like this:
Code: [Select]
Sub Main
  ActValue = GetOEMDro(2000)
  If ((ActValue  <= 9) AND (ActValue  > 0)) Then
    ActValue = ActValue * 10
    GoTo write
  End If
  If ((ActValue  <= 99) AND (ActValue  > 0)) Then
    ActValue = ActValue * 100
    GoTo write
  End If
  If ((ActValue  <= 999) AND (ActValue  > 0)) Then
    ActValue = ActValue * 1000
    GoTo write
  End If
  If ((ActValue  <= 9999) AND (ActValue  > 0)) Then
    ActValue = ActValue * 10000
    GoTo write
  End If
  If ((ActValue  <= 99999) AND (ActValue  > 0)) Then
    ActValue = ActValue * 100000
    GoTo write
  End If
write: ActValue=ActValue+1 'Key 1 was pressed
SetOEMDro(2000,ActValue)
End sub
code not tested, just written down.
Thomas
« Last Edit: April 28, 2017, 11:14:39 AM by TPS »
« Reply #2 on: April 28, 2017, 02:25:42 PM »
Thanks Thomas!
I think I get the idea.  I've played with it some and think I can make it work how I want to.
Thanks!!
Jeff
