Hello Guest it is November 22, 2026, 03:24:49 PM
Author Topic: Help and advise please  (Read 24151 times)
« on: April 27, 2017, 11:07:55 AM »
New member here. I have built an Arduino based controller for a rotary table, an am now exploring the possibility of building a CNC router/engraver. A friend on here built a system from surplus medical equipment.
I found a listing for 4 axis controller, including steppers on e-bay, and would like an honest opinion of it. I know next to nothing about CNC, but am a retired computer tech and hobby machinist, so I think I can figure it out.
Would those familiar with the hardware look at this listing and advise if it is a good deal?
http://www.ebay.com/itm/4Axis-Nema-CNC-Kit-23-Stepper-Motor-TB6560-287oz-in-Driver-board-/152525091236
It is my understanding the above referenced kit comes with MACH3.
Also, anyone know of a 3 or 4 axis mechanical setup that I could apply this kit to? I have a very limited budget, so re-building cheap surplus equipment is the idea.
I would even consider a previously loved setup if you have upgraded. Thanks in advance for any help.
Re: Help and advise please
« Reply #1 on: April 27, 2017, 11:25:21 AM »
It either has the freely available demo version, or a pirated license. Mach3 alone is $175.
I would not recommend it, unless you are building a very small machine driven directly with belts. It won't spin those motors fast enough for a screw driven machine
If you want to build a machine, buy the motors and electronics last, so you'll have a better idea of what you need.
« Reply #2 on: April 27, 2017, 11:31:40 AM »
Thanks Gerry. Your comments make sense.
In getting started, I would only be cutting foam or wax for casting patterns.
In looking at the mechanics, where should I start for something to learn with and build on?
Chuck
