Hello Guest it is November 22, 2026, 09:09:08 AM
Author Topic: Reverse Run  (Read 8458 times)
Reverse Run
« on: April 25, 2017, 12:20:24 PM »
Has reverse run been impemented in M4?  I don't see a function in the documentation or button action for it.
Re: Reverse Run
« Reply #1 on: May 14, 2017, 11:26:46 AM »
Anyone have any ideas on this one?  I see an output for reverse run, but no button action or function to activate it.  Do you just turn the output on and off to activate/deactivate?
Re: Reverse Run
« Reply #2 on: May 15, 2017, 06:25:00 PM »
Anyone?  The manual talks about reverse run and shows images of a reverse run button, but none of the stock screensets have it.
Re: Reverse Run
« Reply #3 on: May 24, 2017, 01:52:49 AM »
Do you mean reverse like the option you can tick in the motor configuration?  (Mach-configuration -> Motor -> Little reverse tick on/off box)
Re: Reverse Run
« Reply #4 on: May 24, 2017, 07:39:10 AM »
No, reverse run like why was available;able in M3.  When activated, it runs the tool path in reverse.  Anyway, tech support says this feature is not available in M4.
