Hello
Guest
it is
November 22, 2026, 07:18:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Conversion Bridgeport Mills
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Conversion Bridgeport Mills (Read 23428 times)
Brian Barker
3,860
Re: Conversion Bridgeport Mills
Reply #10 on:
June 25, 2007, 01:32:46 PM »
You should be able to install Mach3 on the Machine with the Galil card and it should run after you set your motor tunning
If you need help please mail me or post here on the forum
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
2
Go Up
« previous
next »
