Hello Guest it is November 26, 2026, 11:41:36 AM
Author Topic: zero mach  (Read 9204 times)
zero mach
« on: April 21, 2017, 09:04:45 AM »
Hello everybody
i'm new to cncing and i've got a question.
If i set my zero points for my x and y axes what is this point then exactly? is it the centre of my router bit? or isn't it?
Greetings
Thibaud Desutter
Offline Davek0974
  •  2,606 2,606
Re: zero mach
« Reply #1 on: April 21, 2017, 10:20:28 AM »
This point is then your work zero coordinate - the point at which Mach3 will reference all of the moves in your g-code.
It is generally the same reference as that used when creating the g-code, also known as the home reference, work zero coordinate, home point and a few others.
Without this reference, your g-code will be run at some arbitrary position and not in line with the material or design needs.
It is only the centre of your router bit or "controlled point" as long as the machine DRO's show zero for both axes.
Re: zero mach
« Reply #2 on: April 26, 2017, 12:08:17 AM »
Owkey thanks for the help :)
Offline rcaffin
  •  1,073 1,073
Re: zero mach
« Reply #3 on: April 29, 2017, 02:50:31 AM »
'Coordinate Spaces' in Members Docs.
Roger
