Hello Guest it is November 27, 2026, 03:21:14 AM
Author Topic: UC300 quits after 500 lines  (Read 7800 times)
« on: April 20, 2017, 02:34:18 AM »
Hey there
When i run mach 3 with my UC300 it quits after 500 lines. But if i choose printer port it will run many more.
http://cncdrive.com/UC300.html
Anyone have a solution on this?
RBE
  •  9,379 9,379
Re: UC300 quits after 500 lines
« Reply #1 on: April 20, 2017, 03:39:33 AM »
You need a Mach3 license to run more than 500 lines of Gcode.
(you will be able to see and run all the Gcode in simulation mode but you will not be able to output more than 500 lines of Gcode to a machine).
http://www.machsupport.com/shop/mach3/
« Last Edit: April 20, 2017, 03:42:44 AM by Tweakie.CNC »
