Hello Guest it is November 22, 2026, 09:11:11 AM
Author Topic: mach3 run time  (Read 10901 times)
mach3 run time
« on: April 19, 2017, 02:41:21 PM »
Is it possible for Mach3 (full version) to report estimated run time for a file?
Re: mach3 run time
« Reply #1 on: April 19, 2017, 02:57:05 PM »
Yes, on the Toolpath Tab(alt 4) there is a button labled 'Simulate program run' which will simulate the loaded gcode and report the estimated time below.  Not exactly accurate but close.
HTH
RT
Re: mach3 run time
« Reply #2 on: April 19, 2017, 03:01:28 PM »
Thanks for the info.
Re: mach3 run time
« Reply #3 on: April 20, 2017, 01:02:28 PM »
Is there a similar function in mach3 turn?
Re: mach3 run time
« Reply #4 on: April 20, 2017, 01:14:09 PM »
Not in the stock screens.  You would have to use a screen editor like MachScreen to add the button and dro Both Standard Code 15.  there may be a commercial turn set that has it but i have never looked.
HTH
RT
