Hello
Guest
it is
October 20, 2026, 03:58:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Home switches
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Home switches (Read 9689 times)
Kev
3
Home switches
on:
April 15, 2017, 05:12:20 PM »
Hi there, How can I get the axis to step off the home switches so they are clear by about 5mm ?
Kev
Logged
Davek0974
2,606
Re: Home switches
Reply #1 on:
April 17, 2017, 01:12:00 PM »
AFIK there is no setting for this, if the axis is not stepping back or only just stepping back it is likely switch bounce - try adding some de-bounce and try again, might need deifferent switches.
Logged
rhtuttle
575
Re: Home switches
Reply #2 on:
April 17, 2017, 02:11:19 PM »
If I understand you correctly you want to ref an axis which goes to the limit switch and then backs off until the switch is inactive and then proceed another 5mm. If that is correct then choose operater->edit button script and then click on the ref all home button.
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 ) c
Depending on what axis you want to move off from change to:
DoButton( 24 ) ; ref Z
Code("G1 Z5")
DoButton( 23 ) ; ref Y
code("G1 Y5")
DoButton( 22 ) ; ref X
code("G1 X5")
DoButton( 25 ) ; ref A
HTH
RT
Logged
Print
Pages:
1
Go Up
« previous
next »
