Hello Guest it is November 24, 2026, 10:37:16 AM
Author Topic: X6-2200 machine with XHC-USB probing issue  (Read 13667 times)
« on: April 13, 2017, 12:51:12 AM »
I just received a new X6-2200 machine with XHC-USB motion card and config V2.35.6. During probing the machine moves sometimes all axis when it’s supposed to just move down in Z.
Other times it starts to move the Z axis down but stops before the probe triggers and starts to move the X axis. It then moves back to the intended probe position and does a probe routine.
Have another cnc machine with mach3 and the same file work without any problem there. This has a SmoothEthernet motion card.
Have uploaded a video to YouTube with this strange behavior.
https://youtu.be/G-EfMzNZq7M
The probe is disconnected so the machine is supposed to go down to -7.750 and retract.
On the third probe operation it stops at -1.0813, have no idea how that is possible.
Debounce delay is tested at 10 and 100.
Mach 3 version is R3.043.066.
Anyone have any idea on how to get this to work?
Martin
  •  9,378 9,378
Re: X6-2200 machine with XHC-USB probing issue
« Reply #1 on: April 13, 2017, 01:02:10 AM »
Hi Martin,
I think the first thing you should do is download and install Mach3 R3.043.062 (there have been some problems reported with v.066). ftp://anonymous:guest@ftp.machsupport.com/Mach3/Mach3Version3.043.062.exe try it and see if you still get the same problems.
« Reply #2 on: April 14, 2017, 10:58:33 AM »
Don't think there was any difference between the two versions.
I had something to probe underneath so if it tried to move X or Y axis and Z together the probe would trigger directly
Here is the file after probing. Square 10mmx10mm with 1mm interval.
Martin
Code: [Select]
-1.11250,2.00000,8.76875
8.00000,0.00000,-4.18438
8.00000,2.00000,-4.27813
9.00000,2.00000,-4.30312
10.00000,3.00000,-4.32813
7.00000,3.00000,-4.21563
2.00000,3.00000,-4.05312
0.00000,4.00000,-4.04688
5.00000,4.00000,-4.17812
7.00000,4.00000,-4.23438
8.00000,4.00000,-4.27187
10.00000,4.00000,-4.37188
8.00000,5.00000,-4.23438
6.00000,5.00000,-4.18438
1.00000,5.00000,-4.06562
0.00000,6.00000,-4.04062
1.00000,6.00000,-4.07813
2.00000,6.00000,-4.10938
5.00000,6.00000,-4.22187
9.00000,6.00000,-4.39063
10.00000,7.00000,-4.38437
6.00000,7.00000,-4.28437
5.00000,7.00000,-4.24688
3.00000,8.00000,-4.22187
4.00000,8.00000,-4.27187
10.00000,9.00000,-4.51563
5.00000,9.00000,-4.37812
3.00000,9.00000,-4.28437
0.00000,9.00000,-4.20313
8.00000,10.00000,-4.45313
10.00000,10.00000,-4.39063
« Reply #3 on: April 14, 2017, 05:20:14 PM »
I posted a few months ago regarding probing issues with the   XHC controller. They have an issue with GetVar calls. The recommend replacing GetVar(2000),(2001),(2002) with Getoemdro(800),(801),(802).
I did this with my system and it has worked brilliantly since
Sent from my iPhone using Tapatalk
  •  9,378 9,378
« Reply #4 on: April 15, 2017, 12:30:09 AM »
Excellent information Stephenpinn, thanks for sharing.
« Reply #5 on: April 15, 2017, 04:49:34 AM »
Hi stephenpinn,
Did not find any post in your profile showing how to change GetVar to Getoemdro.
Can someone please point me to information on how to change GetVar?
Martin
