Hello Guest it is September 08, 2026, 01:22:40 AM
Author Topic: Screen load script question  (Read 16196 times)
Offline gorf23
  •  190 190
« on: April 11, 2017, 12:00:44 PM »
If you want to call a global function that has been put into the screen load script, is there a special way to call it from a script
I put a WriteRegister function in the load screen script  but if I try to call it from a button script I always get the error
attempt to call global 'WriteRegister' (a nil value)...
Is there a special way to call functions that are in the screen load script or do I need to add it somewhere else also
it will run fine if I have the function in the button script and run debug...
Re: Screen load script question
« Reply #1 on: April 11, 2017, 03:16:53 PM »
Nothing special to run a function from the screen load script in a button script. Just call the function by the same name used in the screen load script and pass it any parameters if it has any.
MyFunction()
MyFunction(param1, param2, param3)
Another way to do it is to put the function in a module. Then you can run it from a buttons script or Mcode. You just have to load the module in screen load (so buttons can use its functions) and in a module that is in the macros folder (so Mcodes can use its functions) of the profile your using.
There has not been a release since I added the load_modules.mcs file to all of the default profiles macros folders but you can manually add it to any version. I have already posted this somewhere before but here it is again.
Code: [Select]
--This is the mcUserScript.lua module that goes in the modules folder
local mcUserScript = {}
function mcUserScript.UserMessage(Message)
if (Message == nil) then --No message was passed
Message = "No message passed" --If no message is passed this will be the default message
end
wx.wxMessageBox(Message)
end
return mcUserScript -- Module End
--This is what loads the module above.
--Add this to the modules load section of the screen load script so you can call its functions from buttons on the screen.
--Add this to the load_modules.mcs file in the macros folder of the profile that will be using it so you can call its functions from M codes.
package.loaded.mcUserScript = nil
us = require "mcUserScript"
--Put this in a buttons clicked script and when you click it a message box will pop up that says... No message passed
us.UserMessage() --This is not passing a message for the Message parameter so the message will be the default
--m110 goes in the macros folder of the profile that will be using it. It will be named m110.mcs
function m110()
us.UserMessage("This is my message") --When M110 is executed in Gcode or MDI a message box will pop up that says This is my message.
end
if (mc.mcInEditor() == 1) then
 m110()
end
Offline gorf23
  •  190 190
« Reply #2 on: April 11, 2017, 07:10:25 PM »
MyFunction()
That's what I thought but doesn't seem to work for me
My Function was called  WriteRegister(param1,param2,param3)
I am passing 3 param's to it... from the button script
then I call it from a button script with the 3 param's
and l get the message (a nil value)...
if I put the WriteRegister(param1,param2,param3) function from the screen load script into
the button script  and call that function form the same button script it works
Thanks gary
« Reply #3 on: April 12, 2017, 08:13:08 AM »
Paste in all of your script......... the function from the screen load script and the script you put in a button that works.
Offline gorf23
  •  190 190
« Reply #4 on: April 12, 2017, 03:23:08 PM »
This works in button script
inst=mc.mcGetInstance()
function WriteRegister(whatregister, regname, regvalue)
    local hreg = mc.mcRegGetHandle(inst, string.format(whatregister,regname))
    mc.mcRegSetValueString(hreg, tostring(regvalue))
end
function GetRegister(whatregister,regname)
  return mc.mcRegGetValueString(hreg)
end
WhatRegister = "iRegs0/%s"
wx.wxMessageBox("WhatRegister= "..WhatRegister)
RegName = "Probe_How" --Y_Probe
Z_Probeprobe = GetRegister(WhatRegister, RegName)
wx.wxMessageBox("Return reg value = "..Z_Probeprobe)
MyRegValue =  "10"
WriteRegister(WhatRegister, RegName, MyRegValue )
regval = GetRegister(WhatRegister,RegName)
wx.wxMessageBox("regval = "..regval)
I put this in screen load
end
end
I tried calling from a button like this
 retval = GetRegister(whatregister,regname)
MyRegValue = "X"
Thanks for your help
I did get the macros and modules to work from a button so over that problem
Gary
« Reply #5 on: April 12, 2017, 09:56:16 PM »
Get rid of the formatting tags and see how it does.
Should be
WhatRegister = "iRegs0"
This isn't right either.........
"core/global/Version"
local hreg = mc.mcRegGetHandle(inst, string.format(your missing part of the srting here .. '/' .. whatregister .. '/' .. regname))
Play with until you can read and write to a single register in debugger then move on to functions then functions with parameters passing.
« Last Edit: April 12, 2017, 10:08:01 PM by Chaoticone »
Offline gorf23
  •  190 190
« Reply #6 on: April 13, 2017, 02:04:44 PM »
ok I will mess with it some more not sure what part of the string I may be missing
and it does work in the debugger as is, I can write to a single register and read
from a single register in the debugger also works as a mcode I saved it as m760
and ran it with the MDI m760 and I put messagebox's to display the results worked fine..
thanks gary
Offline gorf23
  •  190 190
« Reply #7 on: April 13, 2017, 07:11:32 PM »
WhatRegister = "iRegs0" I tried it this way and if when I get register
and then messagebox the results its empty no display seems that I still need it
to be formatted like I had it WhatRegister = "iRegs0/%s" this works for me..
gary
« Reply #8 on: April 14, 2017, 12:19:07 AM »
Good, no shortage of ways to do it in lua, that's for sure. Just pick the way that works best for you.
Something like this might work too......
local hreg = mc.mcRegGetHandle(inst, string.format(your missing part of the srting here .. '//' .. whatregister .. '//' .. regname))
Or
"iRegs0//"
The best way to find out for sure is to just do it and test and adjust until you get what you want.
Offline gorf23
  •  190 190
« Reply #9 on: April 14, 2017, 03:30:42 PM »
just an update
tried this put in a string get get bad  value for #2
Or
"iRegs0//"
Tried this didn't work for me either
seems the way I have it originally is the only way it will run in the debugger at least for me...
But still doesn't fix the problem of having the functions added to screen load script
and being able to call the function from a button if I add the
register functions to the screen load  do I also have to add them to a module ? or a m function?..
