Hello Guest it is October 24, 2026, 02:47:04 AM
Author Topic: Ports & Pins  (Read 7387 times)
Ports & Pins
« on: April 08, 2017, 10:25:48 AM »
I can't get the software to communicate to the Breakout board and work the machine.
I used software from Planet-CNC and it will work using USB from PC to the Breakout board (BOB).
I want to use MACH3, but can't get either a USB or DB25 serial port connector to work.
Using Windows 7-32 bit.
Software and driver test successful.
Using keyboard with MACH3, successful.
Communicate and operate through the BOB, unsuccessful.
Any and all help is appreciated.
Offline kolias
  •  1,165 1,165
Re: Ports & Pins
« Reply #1 on: April 08, 2017, 02:02:32 PM »
Which software does not communicate with the BOB? What kind BOB you have? What kind PC you have?
Nicolas
