Hello Guest it is October 20, 2026, 06:40:03 AM
Author Topic: Probing g31 question  (Read 17557 times)
Offline gorf23
  •  190 190
Re: Probing g31 question
« Reply #10 on: April 06, 2017, 01:18:22 PM »
Just gave that a try still didn't work ran a gnd form the gnd on enternal board to gnd on pokeys no go..
I did test my second board with just pokeys power and it worked so not a wiring problem...
Thanks gary
Offline gorf23
  •  190 190
« Reply #11 on: April 06, 2017, 05:05:22 PM »
got it to work had to use the same power supply running the pokeys ended up putting a voltage regulator
to drop the voltage to from 12v to 5v on my board and it worked..
« Reply #12 on: August 12, 2017, 01:40:36 PM »
One little tip there for the pull up.
Take +5v from one of the axis output pin9 as most of you likely wont use all 8 axis.
I have now done some mails forth and back with Polabs, because of probe failures.. And i got a patch from them today that seems to have fixed the probe problem, they have also innplemented a security that stops motion if probe fails
