Hello
Guest
it is
November 13, 2026, 09:51:02 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach3 under Vista
PC shutdown
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PC shutdown (Read 7526 times)
cesar13
1
PC shutdown
on:
March 31, 2017, 09:20:59 AM »
Hi!
I am trying to make a VB script that shutdowns Mach3 and the PC. Reading in some pages, I came across two possibilities:
1.- Shutting down using OEMButton 705.
2.- Shutting down using shell("shutdown.exe -s -t")
Both of them work, they close all the active programs at the moment and begin shutting down the PC. The problem is that it stays in the shutting down window and takes a lot of time for it to shutdown. Both possibilities. I even get desperate and push the reset button on my PC.
Any idea why this is happening? Or any other idea how to do this?
I thnak you all for your answer.
César
CES
62
Re: PC shutdown
Reply #1 on:
May 21, 2017, 03:57:11 PM »
Hi Cesar,
Try "shutdown /l /s / 0"
That's lowercase "L", "S" and a number zero.
/l means log off, /s is shutdown, and /t is set time to shutdown.
Charles
Print
Pages:
1
Go Up
« previous
next »
