Hello Guest it is November 18, 2026, 11:55:52 AM
Author Topic: mach4 license  (Read 10774 times)
mach4 license
« on: March 27, 2017, 11:04:27 PM »
I'm new to the forum and mach4.  I'm also an ex Ah Ha! user.  My last Ah Ha! board died and forced a change.   I have Mach4 loaded and have tried to get the license to stick.  I get a dialog box that says that the license was accepted but the upper left part of the screen still says "demo". I'm getting conflicting messages here. Probably something I have done wrong.   Any body have an answer to this problem?  Thanks
Re: mach4 license
« Reply #1 on: February 09, 2018, 09:42:05 AM »
For anyone else dealing with this issue, there are three common issues that can cause your license not to stick.
1.) Wrong PC ID. Newer builds of Mach4 will tell you when your PC ID is wrong, so that's easier to diagnose. Your PC ID is shown in the Help>About window in Mach4 and is used to generate your license. If it's wrong, you can fix it by logging in at machsupport.com, going to 'Manage my licenses,' and entering the correct PC ID before clicking 'Add New.'
2.) Not running Mach4 as an administrator. If you're not sure, best to double check by right-clicking the shortcut and selecting 'Run as Administrator.' Windows might ask you for your password. That's your password and not anything I can help you with (sorry!). To make this a permanent selection, right-click the shortcut and go to Properties, then click "Advanced" in the shortcut tab. Select the radio button that says 'Run as Administrator.' This just saves you from having to right-click every time.
3.) Antivirus interference. If you're running an antivirus program on your computer while trying to use Mach4, you're asking for trouble. I recommend not running any programs at the same time as Mach4 (especially when cutting a part!), but AV programs especially can be an annoyance when trying to do things like license your software. You can try adding it to your whitelist (instructions on that are dependent on which AV program you use) but it's safer to just turn it off while using Mach4. Windows Defender, at least on Windows10, doesn't seem to cause this issue. I leave that running on my computer and haven't had an issue the dozens of times I've licensed and relicensed new builds.
Licensing issues are support issues and you can always reach out to the team at support.machsupport.com. Avoid using the Contact Us form for licensing/support because that sends your inquiries to an email rather than the ticketing system that we can all access.
Happy CNCing!
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
Re: mach4 license
« Reply #2 on: September 24, 2020, 02:53:52 PM »
My motherboard on my Windows 7 confuser died and I’m having it switched out. They were able to save all all the old files. Is there something I need to do a la reentering the new machine ID to keep it active running Mach4 Hobby?
Re: mach4 license
« Reply #3 on: September 25, 2020, 02:24:46 AM »
you will have to get a new PCID specific license. If you log onto the NFS you can mange your own license.
You can relinquish the old PCID license and enter the new PCID to get a new license file.
Re: mach4 license
« Reply #4 on: February 13, 2022, 08:37:59 AM »
what is the NFS, is it on machsupport.com?
Is it possible to get a second license for my office PC to make screens and simulation?
BR
Gerhard
Re: mach4 license
« Reply #5 on: February 13, 2022, 08:56:17 AM »
Hi
found it!
2. license works.
Great!
If I had know that I can use on all my machines for 100 $, I would have purchased it years before!
Gerhard
